Hey everyone..new to the board here.
I am curious why everyone seems to say "dreaded Z5"...what is so bad about them?
I just picked up a '98 LX really cheap with 181,000 on it. It runs and drives pretty good, but from doing some searching on the board it appears to be suffering from a couple chronic issues:
1. From the way the starter sounds, one cylinder seems to be down on compression.It also tries to misfire for a little while..and all this is intensely familiar from the Isuzu truck I had that I neglected adjusting the valves on.
These engines are supposed to have valve adjustments aren't they? I would think that neglected valve lash adjustments would be a BIG cause of burned valves over anything else, because even if the valve springs are weak, that would just cause the valves to float at abnormally low rpms in most cases.
Warm however, the engine runs good.
2. The Check Engine light flashes constantly. I'll have to pull the codes out.
Thanks for sharing any input...
PS, this is the second Protege to come into the family..the first was a 1991 LX with the 1.8 BP that my mom bought new...talk about a screamer...that car shifted right at 7,000rpm if I remember correctly.
I know I am able to run 100+ mph in 90 degree corners on the road to my house (which I drove almost every day). So knowing the car and road conditions is critical.
