I have a 97 Protege, I was driving down the highway and it died and wont start gain. It turns over, there was barely any oil in the car when it died, didn't over heat, timing chain is still tight, no visible damage under valve cover, I tried spraying some gas into manifold and that made no difference, when you pump the gas while turning it over it kinda half starts. If anyone has any suggestions please help...thanks
Died and Won't Start...HELP
If it didn't make any horrible noises before shutting off then I doubt you ruined the engine due to oil starvation. If there was absolutely no noise, a good chance is that the teeth on the timing belt stripped yet the belt is still fully on. This happened to me once on a 91 Escort. Upon removal of the upper timing belt cover, the teeth looked fine. When I manually turned the crankshaft pulley, the belt wouldn't turn because the teeth down at the bottom were now shaved off thus just skating on the sprocket teeth of the crankshaft end. Ofcourse, a bad computer can do the same and other things. Get a hand-held computer scanner and see if anything is there.
make sure the pcm has been reset by taking the ground wire off and depressing the brake for 5 seconds or so (read in some manual somewhere) make sure your maf and iac are clean and not obstructed by any depree, (both are along the intake) when my fiance owned the vechicle turned out to just be a bad rotar! (same explaination when she broke down on the freeway) injector failure can definitely be another culpret! Be nice if you could swap for some other injectors, 160cc is the stock spec on our injectors. Only other thing I could think of off the top off my head is whether or not you seized it, or if it was raining and you have cai or something regarding water in the intake? I've ran a toyota dead dry (oil) before but I was only traveling at 35mph and fed it some oil and booyah! check valve? (pcv) not sure, just know that if clogged, car won't idle, take it off and make sure it raddles like a spray can inside.sigpic
Pumping the gas isn't what it used to be. It actually just opens the throttle body to allow more air. The MAF see the increase air and tells the computer to open the injectors for longer.
You may have a bad fuel pump, if so, you would have noticed that it acted like the accelerator wasn't pushed down and you had to floor it just to keep running. If that wasn't the case, it's probably something else. Try spraying some starter spray into the manifold.
Other than that, check Grey1's advise.
Originally posted by dtatham View PostPumping the gas isn't what it used to be. It actually just opens the throttle body to allow more air. The MAF see the increase air and tells the computer to open the injectors for longer.
The air flows across the MAF on it's way to the throttle body. When the engine rotates it sucks air into it creating a vacuum which draws air through the filter, across the MAF, through the throttle body, into the intake manifold, and into the cylinders. There is a bypass to the throttle body, the idle stabilizer, that allows enough air to flow to keep a constant RPM when the throttle isn't being pressed. One of the major reasons why vacuum leaks are such a problem is that it allows air to be sucked into the engine without going past the MAF. This causes the computer to think that the accellerater isn't being pressed as far so it reduces the open time for the injectors and your fuel/air mixture is thrown off.
The vacuum source is the piston moving down with the intake valve open so that it can draw in air. It's basically the same thing as pulling the plunger out on the syringe. The cylinder pulls air out of the intake manifold (vacuum) the air flows into the intake manifold through the throttle body and so on.
Originally posted by dtatham View PostThe vacuum source is the piston moving down with the intake valve open so that it can draw in air. It's basically the same thing as pulling the plunger out on the syringe. The cylinder pulls air out of the intake manifold (vacuum) the air flows into the intake manifold through the throttle body and so on.
