would a 98 z5 engine wirring harness work on a 95 z5 engine?? Are there diffrences between the years??
differences between 95 and 98 z5 harness?
no, yes.
murk loar.Beater=/= Sleeper
The only difference I found was the intake vacume lines are different, and the water temp sensor wire harness were different thats all. I put a 95 motor on a 97. the only differences are the intake but I believe if worst came to worst you could just swap those, the machining is the same, just different vacume set up. My senario seems the other way around regarding years but don't think so. There are very little difference, just the intakes.Last edited by RicardoS; 07-17-2008, 12:07 AM. Reason: left the water temp sensor on my old motor when I turned it in for the core so had to buy a "95" one.sigpic
