I have a new to me 95 Protege, it is giving me a P0335 code, but I can't find the crank sensor or the wiring for it. will this thing run without this sensor?
Crank sensor
Piss poor if it will.Beater=/= Sleeper
Wait a minute, who says he has a BP? As is most likely the case, he has a Z5. I recall seeing that guy that sells engines on ebay stating that if your Protege is a 97 or 98 that all you have to do is take the Crank Position Sensor off your blown engine and put it on the one he sends you. He states, that if your Protege is a 95 or 96 then you will not have one to begin with anyway. Does this sound right?
if its giving him P0335 he has a crank position sensor.
The crap 95/96 z5 I bought had the tooth crank pulley thing to have a crank position sensor. So lets just say it has a crank postion sensor.
The plug is right by the oil dip stick. follow it to the crank pully/oil pan.Beater=/= Sleeper
does it have a plug that empty near the timing cover?
*shameless plug* I have spare cranks position sensors.Beater=/= Sleeper
Do you have any random wires coming out of the fuel rail harness then?Beater=/= Sleeper
20 shipped for one from me. I'll throw in an opposite pig tail if you want too.Beater=/= Sleeper
