Abort Escort's Piston..
    Originally posted by 545HpGt
    i know that toda doesnt build turbo motors, you were the one that brought them up. do with the crank what you want but ill stay with the 1.8 crank and just increase the bore size. and being ignorant is saying that you cant make a 1.8 bp into a 2.0
    FROM Randy Stocker,
    about the overbore:
    "+2mm is safe (85mm), +3mm can be done but you run the risk of walls becoming oval.http://members.aol.com/FE3N/rods.html. Note, you cannot use the stock head gasket over +1.5mm"
    about the pin height change to increase rod length:
    "the stock pin height is 1.108". FM pushed it all the way to the max with a bridge holding the oil control ring up. http://www.gvii.net/dlralt/misc_imag...r/Dscn8824.jpg "
    so...like i said, and have known for over 3 years now... you cannot get a BP to 2L with just bore. Pretty hard to dispute with the hard numbers.
    ever think your machine shop is ****ing with you?
    -93 MR2, 129 ES
    ClubProtege.com Tech Articles
    Originally posted by WTF
      well lets say you have a stock stroke, and want to gain some rod ratio. you would move the pin hight higher up on the piston, toward the crown and ring land. then you would need to install longer rods so that the original deck hight is maintained. (other wise youre deck would go to ****e)
      find it, **** it, forget it
        Flyin' Miata is the world leader in Miata performance and well-engineered, proven Miata MX5 components. We offer parts for a full range of Mazda Miata, MX5 and Eunos Roadsters vehicles.
        2006 Mazda 3 hatchback manual
          which requires custom rods... which are beyond the scope of this topic. Try and READ what was written:
          "if you where to change the pin height then you can stay with the same lenght of rod. and there for just change the crank."
          this will DECREASE rod ratio, if the intent is to go above 2.0L, which was the topic. Therefore, BAD idea, which I already stated.
          I agree, you do NOT want to deal with changing deck height. I'm a proponet of using the stock rods and crank when possible. They're plenty strong for the majority of us, if you need a bit more assurance, just put in some ARP rod bolts.
          -93 MR2, 129 ES
