No! ..
I just used the stock rubber band looking thing that was on the fuel pump...
Everything that was on the stock pump I used, except the dirty ass filter...
btw ..
did you just call me...
I can't pick up yet... not till about 8pm.
Bruce
The pump seems to be working pretty good. I have not noticed any problems with it.
It is very quiet though. I can't hear it at idle or when I start up. It is very quiet for some reason.
No! ..
btw ..
Bruce
mine is installed now
the question i had though bruce, is that rubber thing that you put on the bottom of the pump, then the metal bracket over it.... i couldnt do that
the filter on the walbro pump faces the opposite way than the factory pump, so i couldnt fit the bracket.... how did you make yours fit?
