So what do you guy's think of lucas oil for the engine?
And what do you think of lucas tranny oil?
Make sure before you buy it, ask around if it does form any sediment or crystalize. I used something similar to it and it crystalized in the engine and I had to end up buying a new oil pick up tube because it was clogged and no oil would go to the engine so the oil light would come on, luckily the oil pump didn't go bad, so just make sure before buying additives.
The ATF additive was recommended to me by a local transmission shop, I know they guy so I trust his opinion on it. He told me to try it on my Mountaineer if a fluid change and screen replacement did not solve my somewhat hard 3-4 shift (175k on the tranny)... the fluid and screen replacement worked so I have not tried it yet.
