so can i buy them from 1 of you guys !
also , i need hvac control with A/C for my 98 protege, mine is ****ed ... i mean the overlay it's all skratched !!! it looks like **** !
I have a 95 Protege LX and I have a fuel light. If you have the aftermarket gauges, it overlaps the light. Its hard to see. When you do run out, it'll be a orange light i believe in the bottom right corner. I had that light before i ran out of gas a few years ago lol.
can someone take a pic of the light (or atleast point to the location of the light? This is gay.
The light goes ON as soon as the fuel hand is right over the Empty bar. I recently got a cluster with a tach, and its over 12,4K miles over my original cluster, but I could not wait and slapped it in. Also, I used to have reversable gauges on my DX cluster, but they just stopped working after a while. The only light they did block, was the Over/Drive OFF indicator. Other than that, they were great.
"Probable impossibilities are to be preferred to improbable possibilities."
Because you can't. But honestly, I did not look into that. I just swapped them.
Bruce and some other member have done it with the manual odometer. I have a digital odometer and I'm going to attempt the swap into a 96 instrument cluster.
Are you trying to say it can't be done with the digital odometer??
I want to buy a new set of gauges for my 97 protege SE that has a tach on it. It also has a digital odometer. You guys know any where that I can buy one? or does the 95-96 with tach fit in the 97?
