remote
    remote
    does a 95 protege come with a remote lock and unlock system cuz i brought the car from a guy about 5 or 6 months ago and he found the remote but it dont say any thing about a remote iin the owners manuel
    its probably aftermarket. i dont think that gen had keyless entry yet.
    is it working properly?
      some times it will work but i think i need to reprogram it or buy it a new battery
        usually when the batteries die in those remotes, you'll have to reprogram them anyway. even if from the factory.
        Almost there
        jdm tails... check
        jdm bumper... check
        ms lip... check
        ms grill... check
        ms sideskirts... check
        ms rear skirts... check
        ms spoiler... check
        ms struts... check
        Still trying for a bp swap..:
          no clue bout the 95 but the my 98 has a keyless entry and when my battery died...i just replaced it and no reprgramming needed.
            So you have the 98 protege with the keyless entry. I have that as well. Do you have a black button on the cover for the fuse box in the compartment? I have no clue what its for and what it does. A mystery to me.
