Ok. I tried but still have no idea how you did it. OK, that's possible to slide it in, but there's a black thing on the other side of the pointer that sticking out, and there's no way to get it in if you're not a David Coperfild I guess it would'nt move if there gonna be any damage to motor.
Glow gauges installation and dashboard removal :)
They eventually go on. Look at my pic (but ignore the vertical cuts...that was a previous attempt to install them)
CLICK HERE FOR PICS
1.8L 97 LX (CDN)
Erebuni kit, JDM heads/corners/tails/hood scoop, 17" BSA 259 w/ Khumo Ecstas, KYB GR2 struts, Apex springs, Ractive X-drilled/slotted rotors, KVR C/F pads, EssentialSpeed CAI, Essentialspeed custom cat-back (y-piped with dual Vibrant mufflers), Clutch Masters clutch, touring wing, Vibrant F/R strut bar, AWR 21.5mm rear sway bar, indiglo gauges, Sparco wheel/shift knob, custom interior, TomMotorsports 'BRIDE' seats, Innovatek DVD-0181 DVD/CD/MP3/etc player, Innovatek IN-720 7" indash LCD, 'MZDASPD' plates
It actually read it slowly, If the real rpm around 5 already it will take pointer some time to get there, not even a second , but still a bit slover. It doesn't bother me, but just curious why it can be like that ? I took needle out again and I didn't see anything wrong with it.98 protege LX for appearance
89 626 GT for performance
Originally posted by russianIt actually read it slowly, If the real rpm around 5 already it will take pointer some time to get there, not even a second , but still a bit slover. It doesn't bother me, but just curious why it can be like that ? I took needle out again and I didn't see anything wrong with it.
CLICK HERE FOR PICS
1.8L 97 LX (CDN)
i believe that its on a link in one of the other threads-oh yea search is your friend-i'll see if i can find it... well i see that tricksta already helped you out-my bad; welcome to the forums!Last edited by nativebackup1; 11-30-2008, 10:43 PM.Originally posted by Kitty3 tears probably wont be that visible when installed greatly asseverated by me fingering them in the picsOriginally posted by almighty4wd.......Dude. You own an ECONOBOX. It is not a racecar....
