being too rich isn't bad but being too lean can be dangerous (explosive). but you probably don't have to worry to much about that until you get your turbo
installed my a/f gauge today
In NA, rich (closed loop) is bad...my car runs rich, i dont know why, and my engine stalls out alot...
Not so much now on the sunnoco 94, but, it did today!
CLICK HERE FOR PICS
1.8L 97 LX (CDN)
Erebuni kit, JDM heads/corners/tails/hood scoop, 17" BSA 259 w/ Khumo Ecstas, KYB GR2 struts, Apex springs, Ractive X-drilled/slotted rotors, KVR C/F pads, EssentialSpeed CAI, Essentialspeed custom cat-back (y-piped with dual Vibrant mufflers), Clutch Masters clutch, touring wing, Vibrant F/R strut bar, AWR 21.5mm rear sway bar, indiglo gauges, Sparco wheel/shift knob, custom interior, TomMotorsports 'BRIDE' seats, Innovatek DVD-0181 DVD/CD/MP3/etc player, Innovatek IN-720 7" indash LCD, 'MZDASPD' plates
yeah I have a hard time getting the car to go past stoich . Only when I am warming the car up does it go into Rich... Which is a good thing (frigin burning my gas:p: )
I have been thinking of buying a single pod and mounting the pod on top of the steering column and fiberglassing it in , with some advice from blue_ledz
I also want a boost gauge and a egt gauge. I may want to keep an eye on the engine coolant temp. also ...
Is there no electro thingy that can keep an eye on all or most of these things simultaneously
Bruce
Hey B,
Maybe you should try these...
A bunch of gauges in one convient spot!
S7 5" TACH 4-IN-1 How do you improve on an already phenomenal design. Well we did by creating the S7 Multi-Tachometer. The Multi Tachometer utilizes all of the same design features as the standard S7 Tachometer as well as integrates oil temperature, oil pressure, and water temperature measurements into the background of the gauge. Built in Shift Light.
CLICK HERE FOR PICS
1.8L 97 LX (CDN)
i'm not quite sure but i think the apex a/f regulator does, unfortunatley it does work with your mass air flow sensor. the voltage range isn't compatible. i'm sure i talked with you about the bruce. ours goes from 0 to 7 whereas the apex can only go up to 5.
maybe they updated it, but yeah check it outPatrick Sean-Tiu Santiago
Current state:240 whp and 215.6 ft/lbs torque
FOR SALE $9500
Cardomain
Mmmm...BPT goodness!!!
