why oil leaking out of my Oil cap on my Z5 engine and the oil level is correct.
Replace your pcv valve...I know it sounds weird guys but the same thing happened on my 00, I replaced the pcv and it stopped.According to my Anger Management Counselor, after 26 weeks of anger management class, I should be an expert when it comes to Anger Management...tell that to the guy who threw a starburst at my car in rush hour traffic...haha
Todays thought of the day:
Rice is great if your really hungry and want to eat 2000 of something.
Mitch Hedberg
I don't know if the 2.0L oil cap is different than the 2nd gen but my cap has a separate gasket and when it started to leak I just replaced the gasket (part no. 8871-10-252) and it cured the problem.02 DX Millenium Red - The Penultimate Driving Machine
shake it and see if it rattles....or spend the $3.00 to replace it.According to my Anger Management Counselor, after 26 weeks of anger management class, I should be an expert when it comes to Anger Management...tell that to the guy who threw a starburst at my car in rush hour traffic...haha
Mitch Hedberg
good, But i would change it anyways, its really cheap. Its either the cap or the pcv. either way 10$ worth of repair at most.According to my Anger Management Counselor, after 26 weeks of anger management class, I should be an expert when it comes to Anger Management...tell that to the guy who threw a starburst at my car in rush hour traffic...haha
Mitch Hedberg
