With the 2nd gens.
You fill the tranny from the front bolt.. The way that you check to see that there is enough fluid in the tranny is by dipping your finger in the hole. If you can feal the fluid then it is full.
You can't visually inspect it because there is no room.
I filled my tranny with regular Castrol Tranny fluid..
works great, shifter feals great and it didn't cost much..
Boriqua if you are in the city we can hook up and I will help you change the fluid if you want..
Bruce
Bruce
