i put new pads and shoes on the protege today, and all went good. but the front pads seem to rub on the hub-part of the rotor. makes a grinding noise, but its starting to go away. i tried moving the pads but cant. is this normal on these cars? is it just gonna wear itself to normal?
is it normal for new pads to rub?
1997 mazda Protege LX -4 12" subs,clarion DVD player,clarion H/U
1998 fordF-150 -lowered 6" 20in rims,custom flames,roush side exit exhaust...etc.
1993 Ford Probe GT -New project.
advertisement car:1993 acura NSX ,widebody kit,lambo orange paint,etc.
new advertisement car-1991 nissan 300ZX TTTags: None
hm..weird..never happened to me, you sure you put on the right pads and put them on correctly?Originally posted by 90prtegehave you heard a yaris drive by you??? it says immmmmmmmmmmmmmmmmmmmmmmmgayyyyyyyyy!!!!Originally posted by TurproFk the family. Drugs and hookers take priority first
bpt323: broom break
CRZbrussian: that sux
CRZbrussian: get swifer wet
CRZbrussian: ****s aluminum
theres only one way for them to go on...they have the two pins that go through them, with the clips to hold the pins in.1997 mazda Protege LX -4 12" subs,clarion DVD player,clarion H/U
the old pads are the same size. looks like the just ground themselves to form with the hub so they didnt rub anymore. are they any different between the 1.8 and the 1.5? thats the only thing i can think of.1997 mazda Protege LX -4 12" subs,clarion DVD player,clarion H/U
yup, i used "brake kleen" or whatever its called. you can actually visually see the pad rub on the hub. there is an arrow pointing to where it is rubbing.
My guess would be you got the pad's for an ES which have larger brakes, which would accomodate larger pads. the DX and LX have smaller rotors and calipers and that would definitely cause rubbing, if you got the pads installed.
Mods:
JDM Headlights + Corners
JDM Tailights
1st Gen LX Black Wheels
Shaved Side Mouldings
Cone Filter
E-Bay front strut bar
oki, i took them back out and compared them. the dumbasses gave me ES pads....so now all is fine. :D1997 mazda Protege LX -4 12" subs,clarion DVD player,clarion H/U
Originally posted by rustyglad you figured it out, I work at an autoparts store so I see alot of similar things happen quite frequently.Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
