i was wondering if anyone here knows any ways i could improve the acceleration or speed of my 97 protege LX with a 1.5 liter engine, such as different parts or accesories that might work.
thanks
spencer
Many have asked this same question so there are plenty of answers you can find. You might be dissapointed though. Not much you can do to improve on the Z5 that would really make a big impact.
True cold air intake (you'll have to DIY), a +1/4" exhaust, an MSD ignition, blaster coil, performance wires, grounding kit, and Mazdaspeed cam gears are the most you can do as far as basic mods that will improve engine performance a bit, mostly just by increasing efficiency. Also fix everything back up to tip top shape and make sure it's tuned properly and everything.
thanks
spencer
Welcome to the Forum.
The only way to improve the acceleration or the speed of your Protege is to lighten it and/or increase its HP. There are only two ways to increase its HP: improve its volumetric efficiency and/or improve its thermal efficiency. To discover how to carry out these improvements, do exactly as loganss suggested.
Happy Motoring!
gut everything out of the back half of your car
and do ahome made turbocharger setup.
there ya go...the best z5 you can ever have...
(doesn't say too much) but hey...try it, there's afew of us struggling with it now.
Happy Motoring!
Well put.
what are cam gears going to do on a motor that has the cams slaved together?
I would have to agree with the others on this one, start with intake, exhaust, and igntion. Of course it all depends on what kind of power you are wanting to make. If you want to make alot of power you may want to pioneer your own turbo for the z5.
