I was thinking about this possible solution to your axle problem. What i gathered from you is that the 1.5 intermediate shaft wouldnt bolt to the 1.8L block or whatever it bolts to to prevent torque steering. Basicly what i was thinking was to take the 1.5L/MT intermediate shaft and taking of the u-joint hubs. Do the same to the 1.8L/MT and then put the 1.5L/MT u joint hubs on the 1.8L/MT shaft. It might work if the 1.8 and 1.5 u-joint hubs arent diffrent sizes. If they are i doubt it will. I cant explain it to well but i made a pic to help out. Heres my awesome paint skills. Let me know if this would work.
Bruce, Solution to your axle problem?
the intermediat shaft, does not go all the way into the tranny, this is because the blocks bolts don't line up with the bolts on the intermediate shaft.
To get the lined up, the axle will stick out a bit. I have the intermediate shaft for the G tranny, but it will not fit in the F tranny. So I basically won't work.
Otherwise, I haven't had any problems with the tranny ..
