I'll move it eventually, maybe today. I have a 22* bend I can put on the end to get it closer to the headlight. Maybe a heat shield or heat wrap to help keep it cool. I'm actually surprised how well it fits.
Thanks. I was actually thinking of this earlier. How much good is an expensive cold air intake setup if the tubing is going through a hot engine bay? Without any heat wrap, which I haven't seen in anybody's pics, the tube is going to heat up, therefore warming the air inside the tube. So what's the point if it's sucking warm air anyway? Unless of course you have it wrapped in insulation.
Just my thoughts on a CAI. You can ignore if you'd like.
So at the throttle body lets say, there is no percievable difference between a cold air and short intake because the tubes will heat up just as much no matter the air temp being pulled in. Therefore the air temp at the throttle body is barely different because, either way, that air had to travel throuh a hot engine bay. So a CAI is just a mind trick for some company to make a lot of money. That's how I see it anyway.
So a longer intake tube increases the speed of the air coming in. And usually because aftermarket intakes have a slightly decreasing diameter?
So the real argument over which is better should completely ignore the temperature of the air and focus on the velocity of the air going into the manifold, because a higher velocity gives higher air flow. I'm not saying the temp has no affect, but the fact that it passes through a hot engine bay is going to warm up the air from a CAI anyway.
Mine has been sitting in front of my house for a week and a half, waiting for an alternator transplant. After that, I'll have some updates as I winterize it and try to sell it.
