My 98 has a new compressor, receiver/drier, and a new condenser fan. When its cycling the low side is 30 and the high side is 275-300. It cools great, except when it doesn't. The past two days when I leave work and the outside temp is 95+ and the in-car temp is 140 the inside fan will blow but the power to the clutch is not on. Test light says no power. I can jumper the clutch wire and it will run. The led in the AC push button switch says I have power to the switch. Got home today and left the hood up while I ate. Came back out and I had power on the clutch wire. Second time its done this. Anyone have experience with this? A particular part I should concentrate on? It works fine until it gets hot.
Anyone have a copy of the wiring for a 98 manual trans AC system they can post or email?
Thanks
Paul
Thanks
Paul
