Well i went to pepboys to get sum air fresheners today and decided to look @ cone air filters, i came upon a driving light kit, 2x5 rectangles with wiring kit, switch and something else i cant remember but they are $29.99 and are basically foglights both have 1 h3 55w bulb in the housing and i cud replace those with Luminics JDM yellow if they suck so i was jus thinking what do u guys think?
Driving Lights in the bumper
Do you want driving lights or fog lights? They have two different beam patterns and light throws and are meant for two completely different purposes. A good set of driving lights can illuminate the road far beyond the capabilities of your high beams whereas the downward-directed beam of the fog lights will illluminate the road closer in and prevent the light from being reflected back into your eyes by the fog as happens with normal low beams.
If you just want the lights for appearance then you can't go wrong at that price but truly effective driving or fog lights from, for example, Bosch, Cibie or Hella, cost substantially more.
Originally posted by goldstar View PostDo you want driving lights or fog lights? They have two different beam patterns and light throws and are meant for two completely different purposes. A good set of driving lights can illuminate the road far beyond the capabilities of your high beams whereas the downward-directed beam of the fog lights will illluminate the road closer in and prevent the light from being reflected back into your eyes by the fog as happens with normal low beams.
Happy Motoring!
thanks, i just want another pair of lights to go with my headlights so that i can see better @ night im gonna buy the driving lights.NO longer owns a 96 protege!!!
Read. It's full of useful lighting information.
If you're considering using those lights from Pepboy's to actually enhance your car's lighting, I'd say don't waste your money. I seriously doubt $30 can buy an effective set of fog lamps. If, as goldstar said, you just want the look, go ahead. Just make sure you get them aimed properly so you don't blind anyone.1995 626: daily beater, mostly stock. Future NASA racer?
Next up: Speed6 or RX-8
Originally posted by 1Mazda323Fan View Posthttp://www.danielsternlighting.com/home.html
You asked for opinions, and you're getting them. Sorry if you don't like them, but we've all been saying the same thing. Observe:
Originally posted by goldstar View PostIf you just want the lights for appearance then you can't go wrong at that price but truly effective driving or fog lights from, for example, Bosch, Cibie or Hella, cost substantially more.Originally posted by 1Mazda323Fan View PostIf you're considering using those lights from Pepboy's to actually enhance your car's lighting, I'd say don't waste your money. I seriously doubt $30 can buy an effective set of fog lamps.Originally posted by firelizard View PostThey're probably going to suck.1995 626: daily beater, mostly stock. Future NASA racer?
Originally posted by Beerizfood View PostI would start by dealing with those nasty clouded headlamps to improve vision.
They're also an eyesore.
i'm most positive if u get those bulbs they will have a crappy output with light;
i don't believe there is anything firm there u can bolt them too..so they might just go bouncing everywhere.
i say u don't get them.
if you seriously want some foglights and your willing to put some work into it.. i have some polyeurathane inserts that i can sell u that will fit nicely into your bumper. all u have to do is cut a circle.. then PL the eurathane insert in the hole u made and stick a fog light in it.| Ejaz | '98 Protegé | '02 Protegé5 |
