I got a 2inch exhaust custon make should I put in one or two resonators
To get the best flow i'd advise to get matching piping width as well, an extra 100$ max. You should have at least gone 2.25 cat back. As far as resonators, i would go with none. its not going to be super loud regardless.Patrick Sean-Tiu Santiago
Current state:240 whp and 215.6 ft/lbs torque
FOR SALE $9500
Cardomain
Mmmm...BPT goodness!!!
What kind of muffler are you going to use? Also, is your car manual or auto. Canister type mufflers are loud as hell with automatic trannies, even if you have one resonator in there, it will not help. I used to have a Ractive canister type axle-back. It resonated like crazy even with the stock resonator in place. But if you have a stick, then do not worry about it. It should not be as annoying as the automatic tranny."Probable impossibilities are to be preferred to improbable possibilities."
Originally posted by turbonium959What kind of muffler are you going to use? Also, is your car manual or auto. Canister type mufflers are loud as hell with automatic trannies, even if you have one resonator in there, it will not help. I used to have a Ractive canister type axle-back. It resonated like crazy even with the stock resonator in place. But if you have a stick, then do not worry about it. It should not be as annoying as the automatic tranny.
well put turbo. =)Patrick Sean-Tiu Santiago
FOR SALE $9500
Cardomain
I have the Generation II Arospeed 4" straight tip canister muffler
and it sounds great with my 1.5 auto. it also has the resonator still
on too. Not too loud but still noticeable.
just installed today. i'm very happy with it. i heard that it still
has to break in so it might get louder.Mike A.
Yeah, personally I'm not a fan of cars that are really loud in all rpm ranges (even ferraris aren't that loud in normal driving. If its loud at WOT, that's one thing, but if you're just pulling away from a light. . . it's just annoying. Hopefully I'm going to be doing a full exhaust later this summer (2" stainless mandrel-bent custom, hi flow cat, and magnaflow(?) muffler). I don't want loud, I just want it to sound good. . . just my .02 Good luck with your exhaust!
Originally posted by mig360mWhen I had my stock exhaust I maked about 180km/h easy now 170km/h if lucky. A mechanic told me to put on a other resonator."Probable impossibilities are to be preferred to improbable possibilities."
Originally posted by Project323To get the best flow i'd advise to get matching piping width as well, an extra 100$ max. You should have at least gone 2.25 cat back. As far as resonators, i would go with none. its not going to be super loud regardless.
2.25" is too big IMO. 2" is still slightly too big unless you've done some work on the motor."Never run out of real estate, traction & ideas at the same time"
-93 MR2, 129 ES
ClubProtege.com Tech Articles
