The Man. u got a manual for the 97-98 pro?
Could It Be The Master Cylinder
physically replacing the master cylinder is not hard
as edwin said, you must take care while bleeding it
with a new master cylinder you're starting from scratch so the entire system needs to be bled properly
start from the furthest wheel from the master cylinder and work your way towards it
also, when you try to activate the ABS pump look for a gravel road... what you want is to lock up the wheels to get the pump to work, to move the fluid/air and pull in fresh one
you might have to do it 2-3 times tho... its a huge pain in the ass
