brake upgrade
    Originally posted by 95pro View Post
    was that on a v6 swap that i've seen before? the 5 lugs?
    No, it was on this car
      ewwww...
      Almost there
      jdm tails... check
      jdm bumper... check
      ms lip... check
      ms grill... check
      ms sideskirts... check
      ms rear skirts... check
      ms spoiler... check
      ms struts... check
      Still trying for a bp swap..:
        nice color though...that's the color i might go with on the 95.
        Almost there
        jdm tails... check
        jdm bumper... check
        ms lip... check
        ms grill... check
        ms spoiler... check
        ms struts... check
          I don't mean to get on your case, but did you really need to make two posts?
            ok i figured that the 5 lug wasn't existant. so it is easily possible to just swap the ES rotor correct? i just bought 17" and really sticky rubber and now my car can't even lock up... the brake pads are not more than 5 months old. can increasing the diameter make a large diff with stock pads? i can tell that i need steel braided lines they don't feel solid and i do not have any air bubbles.
