yes you need new struts with ground controls
Lowering my 98 Protege...
Beater=/= Sleeper
Originally posted by Kitty View Postyes you need new struts with ground controls
and i need to change those struts soon
would i be able to put on new struts
like the kyb onez
and always throw on b&g springs or even that
ground control coil over kit more in the summer| Ejaz | '98 Protegé | '02 Protegé5 |
you could do that but it requires the same work twice. i had a set of ground controls on my old 98 GTI and i hated them, i never raised them and the slam wasnt enough, on that car i did end up buying full coilovers.
why dont you just cut 1 coil off your stock springs and put the new shocks? those tall stock springs have plenty to be removed before you affect your shock. its a thought and its free, im thinking thats what i should have done.check it out...
http://www.yarilswork.com/
Originally posted by tylordurben View Postyou could do that but it requires the same work twice. i had a set of ground controls on my old 98 GTI and i hated them, i never raised them and the slam wasnt enough, on that car i did end up buying full coilovers.
well i got me those
4 kyb gr2 struts and they ran me about
55 buckz a piece alot better than alot of places so i'm waiting for those to come in
and to be honest man for my everyday car i wouldn't mind sitting at where your at right now
so do you think
the ground controls
would get me that low| Ejaz | '98 Protegé | '02 Protegé5 |
nice, $55 each is a decent deal. GC's drop over an inch, but not greater than 2. get 5 really really fat people to sit in your car to get an idea what that'll be like.No car! I soldz it. Now I have a truck. I like it, but apparently it has a hard time keeping up with a slightly modified 4WD protege with half the hp. Neat.
Originally posted by almighty4wd View Postnice, $55 each is a decent deal. GC's drop over an inch, but not greater than 2. get 5 really really fat people to sit in your car to get an idea what that'll be like.
If you get them mounted correctly you can diffintly get a 2-2.5in drop. Your struts wont last for shi- but you can diffintly get 2inches+.Beater=/= Sleeper
yes with coilovers on a 2nd gen. 2" or greater drop is acheiveable.Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
does anybody here have regular springs that haven't been modified
and not coilovers
cause im confused...
tylordurben.. got a "descent drop" with those 2.25 b&g'z after mods
and no other springs that goes for the 95-98 protege gives you that much
anybody
used different springs
and got a good drop out of them
like the h&r'z or something| Ejaz | '98 Protegé | '02 Protegé5 |
i hear ya cause i too wanted a descent drop and nobody claimed more than the B&G with the 2.25" so thats what i went with and then obviously had to modify.
i personally dont think ill spend the money on "sleeve" coilovers ever again. dont get all confused. find the springs shop around and if not cut your stock springs 1 coil. it will be about the same drop and maybe ride quality will be just a bit slushier than mine.
kitty why is that you say the struts wont last?check it out...
Originally posted by firelizard View PostFor the record, I have a hard time finding places to scrape my car, and I'm at least 4" lower
So don't be afraid to go low - I noticed that was a concern on the previous page.
im just trying to find me a way there
without coilovers| Ejaz | '98 Protegé | '02 Protegé5 |
Originally posted by firelizard View PostYou could do air.
More expensive, but more comfortable.
Probably eats GR-2s for breakfast though. Would need Koni inserts, I hear those are shorter.
i was wondering
cause some1 asked that
sooo
if i get those ground control coilover springs
i need koni inserts
butt
y do they eat struts?| Ejaz | '98 Protegé | '02 Protegé5 |
