well i got a wicked deal
on 4 gr-2'z
so their already coming in
just wondering
what to do
with my
springs
and what to get
let me guess
you got coiloverz too rightt?
lowering too much decreases the suspension travel.
i.e. the piston is already compressed when a car is lowered.
it'll cause the piston to bottom out due to limited travel. therfor overworking/killing any oem/stock-replacement strut.
the only way to combat that is to:
1) get a shorter strut - custom or possibly koni-inserts
2) get an adjustable strut(mazdaspeed struts) - will control the "rice bounce" and offers improve rebound and/or compression
3) get the ksports (a full coilver system, GC's are not a full coilover system)
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
if you're going to spend money like ksports, get the koni's, get a good coilover, fab it up. it'll be far better than the ksports, for 15% more in cost; $600 struts, $250-300 coilovers, $250-300 fabbing.
the mazdaspeeds are also in the same price range, and just as good.
hmm
well i got me
4 brand new gr-2'z almost here
and im just gonna either
get
those
b&g'z with 1.5" drop
or
i'm going to get the intrax onez with the 1.7inch drop if i can find them
i'll see the most i can get out of some springs
