had a spare hour, so i went ahead and cut the rear springs, 1 coil. i think ima leave it as is for now. its not slammed, but its now noticeably lower than a stock one.
what springs did you go with (the ones you cut) tylordurben?
yeah i used the red B+G springs 2.5" drop (they are pictured on this thread) and I cut 1 coil off the bottom on each of them.
It looks good now but me personally would never disrespect b&g springs lol
How much lower did the one coil drop it? Do you have nearly identical pictures so i can compare? I like the final product, if it isn't a bit too low I would just like to see more of what it looked like before you cut the coils.
(I saw the other pictures and was just wondering if you had any more)
well, thought i would finally post a pic of the 1.5 coils cut up front, im still not completely satisfied with the stance but it will do for a while...
If you wanted a lower drop why didnt you go with a gold line or intrax spring?
Beater=/= Sleeper
