Strut Bar
    There are still 2 strut mount bolts holding the bar in right? One that you can't see in the picture, and then the one next to the cruise control, correct?
    I would say you're better off cutting off that part of the endplate that is interfering with the that third strut mount nut, because its not allowing the strut mount to seat properly against the strut tower and thats going to either eventually come loose since its crooked, or damage the nut/stud.
    Im not sure if that strut bar came with that rectangle section already removed from the endplate, but if it didnt, it woulda been a better idea to just drill a hole for the third stud, as Ryan suggested.
    Make sure that no matter what, you don't just remove the bolt... that is 1 of the 3 bolts holding the shock/strut to the chassis, and thats the only reason why im saying its important to make sure its on there properly.
        The strut bars "lock" the strut towers in place. So whatever your alignment is set at, will remain true under hard cornering because the chassis is unable to flex. It doesn't actually "pull" anything together, or make any changes. It just prevents unwanted changes.
        As for the rear strut tower bars, check out this thread.
        I know the basics of a strut bar and what are its benefits. I was just asking if it's a straight bolt on or does it require some measuring, thinking and setting.
        Garage: Mazda Protege 1995, Z5 engine, MTX, P/S, no A/C, no ABS.
        PM me if you need: comprehensive Autodata information; Mazda's 2nd generation workshop manual; Mazda's Z5 overhaul workshop manual.
          just cut a washer so that the bolt sits flush. much simplier.
          Originally posted by 1967cutlas
          You make a lot of grammatical errors for such a refined gentleman.
            You da man. That was what I was going to post also and forgot. I think it is the easiest way to go without more work.
            Although the nut may not turn when it gets close to the bracket.
              ya you could also do that, put something to take up the space... so the nut sits flush on the washer/bracket, and the washer/bracket sits flush against the strut tower
              just make sure that it can't slip out, cause that would really **** everything up
              i'd still just cut off the edge of the bracket, its not doing anything in there aside from making things complicated
                whoa chill out there santos.... this $200 nonsense is way off..... if you search ebay & really really pay attention to the auctions you will notice that their are 2 kinds of strut bars available. (as far as endplate wise) I prefer the full circular endlplate- in y our case it would be much more benifical to have, life goes on no worries.
                  the ones with circular end plates have 0 holes matching the bha bolt pattern
                    Ya, but at least material is there for you to drill your own holes
                      ^ as chris said
                        Thanks for the picture, I think I can get that now, maybe after winter. As for the other comments,I drilled the third hole, as not to mess with the integrity of the plate. I am thinking of buying another one....for a little special project that has been running trough my mind.
                        This is my BP. There are many like it but this one is mine. My BP is my best friend. It is my life. I must master it as I must master my life. Without me, my BP is useless. Without my BP I am useless. I must drive my BP true. I must drive straighter than my enemy, who is trying to beat me. I must beat him before he beats me.
                          whats this special project??
                            When the rain breaks or the weather warms, you guys will see!
                              Now you got me curious. Lol. Sub'n
                                Maybe his sunroof was leaking and he fixed it.
