looks good!! great stance on the car overall too!!
Got these today.
its canada it has to have drls.Beater=/= Sleeper
Originally posted by Kitty View Postoil pressure is alittle high there
also to knit pick your engine bay I would try to route the return fuel line under the fuel rail. Looks busy running over the top of it.
Im shocked you didnt say something like wow high oil pressure yet no fuel
pressure or ....nice emblem on the grill
Serious though, i need a proper 180 degree AN6 to fix that line on the rail.
That also will come after the turbo install.Powered by ACME
Originally posted by goodorange View PostI like how the bumper and lip is panning out.
do you have dtrl's or city lights wired in your headlights?
Im well pleased with the bumper and will go ahead with paint for it.Powered by ACME
Originally posted by bpt323 View Postlooks good!! great stance on the car overall too!!
Gonna line it up first at work next week then play a little.
I still have to install the MMS rear sway bar which will obviously change the back end responce.
Again thanks for your support through this thread,the positive reinforcement has had a definite impact on getting this done.Powered by ACME
Originally posted by Beerizfood View PostHahahaha i was wondering if anyone would notice the oil pressure and guess who did? Actually i havent installed the oil pressure sender yet cause im gonna connect it into the turbo oil line when i get to that point.
I say go ahead and replace the oil sender now. The one I had had 2 ports for for the stock idiot light and one for the gauge. It'd take all of 5 mins during and oil change and would make you less of a ricer running around with non working gaugesBeater=/= Sleeper
Originally posted by Kitty View PostI couldn't make out the other gauge honestly.
LOL at < ricer.I need to fix those "gills" on the fenders next.
On a less ricier note that fuel gauge is real handy with the adjustable
regulator.You should see the wideband react when i raise or lower the pressure.Powered by ACME
Originally posted by firelizard View PostRide height is really high for me
I can 100% guarantee you won't scrub going lower.
How's your roll center though? I know I'm lower than optimal, but just looking at it are you above it?
How do you compare roll center?Powered by ACME
apparently, the ideal control arm angle is perfectly horizontal. Higher or lower apparently increases body roll or something through some suspension geometry that I don't understand fully. The basic idea though is that you want your control arms parallel to the ground.
You'll get scrubbing on hard turns, or with 4 passengers once you're tucking a little tire, in my experience. So a touch above that is likely the more practical. At my ride height, if I were running regular offset wheels I wouldn't scrub at all.
Originally posted by firelizard View Postapparently, the ideal control arm angle is perfectly horizontal. Higher or lower apparently increases body roll or something through some suspension geometry that I don't understand fully. The basic idea though is that you want your control arms parallel to the ground.
The control arm appears to be relatively flat .i will measure it when its on the rack.
4 passengers in a z5? We might as well push it.
I like the drop you have ,its insane.How much shock travel do you have in the front?Powered by ACME
