Good choice on the pads. Be careful you don't buy ones that are too aggressive, otherwise you won't be able to get enough heat into them to stop you car. Stay away from the full race pads. As for the rotors, get a good set of replacement blank rotors. There's no need to get ones that are drilled and/or slotted. Drilling makes the rotors weaker, and slotting just reduces the surface area of the brakes. For street driving, a blank is all you need. I've had good experiences with Brembo. And the stock size isn't too small unless you're planning on running the 24 Hours at Le Mans. For everyday driving all you need is the stock size. Save the money you would have spent on a big brake kit or replacement parts to fit bigger OEM rotors and spend it on stickier tires to further help the braking performance.
1995 626: daily beater, mostly stock. Future NASA racer?
talk to anyone whos driven the 9" brakes and the 10" brakes, and they will tell you of the pathetic stopping capability of the smaller rotors.
lol well i know, but can i do anything with a 13in steelie? i feel like im stuck with small rotors till i get a bigger snow tire :-( i really want bigger rotors...
Originally posted by Kitty
3 tears probably wont be that visible when installed greatly asseverated by me fingering them in the pics
Originally posted by almighty4wd
.......Dude. You own an ECONOBOX. It is not a racecar....
You are "stuck" till you get bigger snow tires. But you could always sell the ones you have.
If I were you I'd throw some cheap pads on there to get through winter, then do the upgrade, sell your snow tires and buy some 14" ones at some point for next year.
