If anyone remembers me talking about replacing the passenger's side CV axle about a year ago, my dad and I also replace the front brake pads. Less than a year, and a few thousand miles, later, the passenger's side pads were virtually gone. The inside pad was, well there was no pad, and the outside had maybe a millimeter or 2 left. The driver's side? Looked brand new. So I replaced both sets of front pads, but the passenger's side was always way hotter after driving and also stank like, well, burning pads. Turns out the spring came loose somehow and rubbed on the edge of the disc until it snapped. Got new springs and pins from Pepboys, hoping to solve my problem. Changed both sides. Didn't solve the problem. Still nothing wrong with the driver's side, but passenger's side still stank and was way hotter. So I took out 2 shims from behind the inside pad, hoping this would work somehow. The only change was an increase in squeaking. The inside of the passenger rotor is slightly grooved, probably from when there was no pad, but my dad said it wasn't in immediate need of replacing. He owned an auto body/mechanic shop way back when, so I trust most everything he says.
I've never disconnected the brake lines so I never had to bleed the system, so there shouldn't be any air in the lines. Thinking maybe I should replace the rotors. If that doesn't work I'll change the calipers. I still have the spring from the driver's side which I'm going to stick on the passenger's side tomorrow, maybe two springs will hold the pads away from the rotor better than one? Not sure really, just brainstorming/thinking out loud.
Has anyone else had a similar problem or know of a solution? Throw out any ideas you have, and thanks.
