ya we were having a good laugh about the bp vs fs scenerio with my coworkers today.
how much boost were ya running?...just 21psi.
Holy crap! did ya bend a rod? nope. did ya melt a piston? nope. did you loose oil pressure in a turn or under boost? nope.... then what the heck happended?.... freeze plug fell out.....lol oops.
S197 Mustang GT Convertible The New DD. (Ford Racing 3.73/JLT CAI/SCT SF3 Tuner/Ford Racing Exhaust) 2009 Nissan Rogue SL AWD Maximus Tractionous Wifeymobilious Previous ~ 235whp 1.8 BP Powered 2003 MazdaSpeed Protege ~ - Sold
21 psi on a stock fS engine or am I missing something
your missing something...lol im running 1.8 BP drivetrain
1993
Engine
Ford Escort *DOHC (1.8L, VIN 8)- 137K,RUNS GOOD M1635 250
--Can--
$250.00 Saunders Auto Service -- Store 1 Can-ON(Thorndale) Request_Quote 1-800-265-0369 Request_Insurance_Quote
just use car-part.com to find something local.
if you dont mind doing the work yourself then cannot have more fun for less money in a msp. i have less money in my current setup than i sold my stock msp engine/trans/ecu for.
here are some pics from when we swapped in the small nose BP last week.
the thermostat housing is held in by a bolt on one side and a stud/nut on the other. My stud broke in half the other day. (of course after we installed the motor lol)
Does anyone know if that stud is replacable? IE Can i heat it up and pull it out of the cyl head. Or does it need to be ground flat and then drilled/tapped.
Im hearing different things depending on who I ask..
Can anyone confirm?
I could have sworn I remember pulling that stud out once when I had an issue like 8 years ago with an old EGT, but so far it has not budged and my buddy is telling me I gotta grind it flat then drill/tap..
what I need confirmed is whether or not the stud is screwed into the head (IE Is the stud replaceable?) or do i need to drill/tap.
I think I can recall pulling that stud before, but I may be thinking of something else. I'd say its 50/50 that I'm thinking it was the BP in my dark green EGT. Sorry not much help... Engine/trans looks good though!
Current:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
can you cut a slot in it with a dremel heat it up a little with a torch and use an impact screw driver to get it out. my guess is that it will come out without having to drill and retap.
If you can't unscrew it out then grind, drill, retap and install another double threaded bolt. Steel into aluminium is apt for corrosion especially near coolant and who knows; there could be loctite
