but it is that easy. you look at the pin out on the ecu and wire up the ones that go to the obd2 16 pin connecter. its only a couple owires. and you can mount it near the ecu
My 2002 KLZE Protege 5, kl to kj swap thread
Hmm I guess your right.... I'll head up to the junkyard this Saturday then and grab the port and go from there
1988 323 GT - B6T Powered
Ya that's messed up man, sounds like it might just be going in to safe/limp mode for some reason...I hope you can figure out the issue! Sounds like wiring in the diagnostics port is the best way to start lol see if it tells you anything, which it probably will-Jack
Oh I'm sure I'll get it figured out eventually, I'm too dam stubborn to give up on a project haha
any CEL's? the KL/KJ ECU management sucks balls apparently---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
lol nice ryan, way to miss out on the who odb2 plug in port missing-Jack
ahhhhhhhhhhhhh.................---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Haha all good Ryan, junkyard run this Saturday to pick up the port, maybe a few other things as well, hopefully I can get this dam thing figured out soon
Originally posted by FE3-323 View Postany CEL's? the KL/KJ ECU management sucks balls apparently~PaTricK~
-Current car's-
What are you driving?
Yep I'd love to convert my 93 to KLG4 electronics and intake system lol-Jack
that easy? even for odb1 KL cars?-Jack
So today me and jack (Mazda_Powered) went to the junkyard, and i got a set of Milly S injectors (for the festiva) a spare KJ ECU, a diagnostics port to wire into the KJ harness and a front pass. ABS sensor
Now hopefully i can figure out what the hell is going on with the swap
good score today lol-Jack
