i wanna at least go for a ride in it sometime
My 2002 KLZE Protege 5, kl to kj swap thread
So, I couldn't resist; I took it up and down the road for a quick rip. While it runs, there is very little power. Runs and accelerates perfectly smooth. I figure I have to trick the factory bypass valve which limits boost in the stock Millenia in first gear. Not a big deal, it's drivable as it is, I'm very pleased.sigpic
1992 Familia GT-X
1988 323 GTX
2011 F150 Lariat Ecoboost
2014 Civic Touring
I'm glad to hear your happy with it man.... As for the lack of power, do you think that could simply be from having the make-shift MAP in there?
1988 323 GT - B6T Powered
Yeah, could be.
Edit: This has to be the issue. I'm not getting any boost at all, the sensor range is way out of whack. I guess it's just close enough to not throw a code anymore. I don't know if a new MAP sensor will give me full boost, but I'm confident it will at least give me the 7psi limited boost as it does in first gear. There is no info anywhere on what it boosts with no transmission signal, so I'll just have to hook it up and see what I get. If I only get 7 psi, all the time, I'm thinking the computer would be happy with a manual boost controller in front of the MAP sensor, such that when I get 14 PSI, the factory boost level, the MAP sensor will see 7. I just don't know how well that would work with vacuum, so I'll put in a tee before the controller with a check valve, route that to a tee after the controller, so the MAP sensor will read proper vacuum. I'll also have to install a A/F ratio gauge to make sure she doesn't lean out.Last edited by DuRWooD; 01-07-2012, 03:28 PM.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
a good running KJ is pretty impressive- even in a millenia's heavy body.
or so i thought @ least. It would **** all over a normal KL thats for sure.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
^^^I agree with that!
I cant wait to see this thing in action.Josh
95' AWD MX-3 RST - Still a work in progress
05' MS RX-8 - Needing some love in the form of a new motor, soon to be FE3 powered
Work Log - http://www.wihandyman.com/forum/showthread.php?t=53776
Cardomain Page - http://www.cardomain.com/ride/408020
Face Book page http://www.facebook.com/pages/Mazda-...37983472959216
I found the sensor trims I was looking for. The sensor I'm using maxes out at 0.5 psi, the Millennia seems to be around 16 psi. If I get some time tomorrow, I'll put something in to see what kind of power I get.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
what about a sensor from an RX7??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I got excited last night as I went home from work with a GM "2 bar" MAP sensor in hand, just before I hacked it up to solder wires on it, I decided to measure the output. It's a ****ing 1 bar. It seems BWD lists a 1 bar map sensor for the cobalt ss, when it should in fact be a 2 bar. Then today I call up JET Performance to enquire about a custom burn for my millennia ECU, they tell me to fax them the details! Jesus, I wonder if their tuning is as rudimentary as their customer service. So anyway, this is turning into a BJ bitch log lately, I promise to have it running soon!
If anyone can flash my Millennia PCM, pm me. I need the safety boost cut disabled.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
idk can milly ecu's be flashed.
oh- can you look up the milly S FPR pressure for me pretty please!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
yea me and chris are going tomorrow to hopefully grab a sensor for ya lol-Jack
