Originally posted by bomdoutscort
View Post
Awd mp5
yep got 2 bolts in to line it up and give it a quick test drive tonight. it worked but I think I need to do some more work now on my other mounts to get the setup perfect. when i let off the throttle quickly it feels a bit unsettled. going over bumps in the road seemed odd too.
I'll be getting ready to drop the real motor in for the last of my passenger side mount adjustments and crossmember mounting layout done and set in stone. Decided to start working on modifying the FS driverside top mount bracket so that it utilizes one of the original BG tapped bolt holes. I'm not too keen on relying on those partially tapped holes for studs. I'm still deciding on whether or not I'm even going to use those, we'll see.. pics to follow of what I've done so far.
the more i look at this pic the more i think i want to remove my bg crossmember and mod the bj one to work.
Worked on tweaking the FS mount for a solid fitment on an EGT case. Isn't pretty yet.. still more work to be done to it.
Guess it's my turn to play whats in the box However, it's probably uber easy to figure it out lol.. Should be here by Thursday!
See ^ easy..! Also going to attempt to get my manifold welded up this coming week if time permits.
Originally posted by M323GTR View PostSweet EWG Im assuming
Old pics are old. The collector is flipped in the above pic because I didn't originally plan on going top mount.
Yea top mount.
Should make for some fun or make the rods scatter like roaches when it comes into boost lol
