Awd mp5
    10 inch and I think the cfm was around 1400 each. I don't remember off hand.
      whats this...bg guys hating on us bj guys..o wait its only ryan lol :p
        Hmmn.. This method or the dog bone? Trying this out to see how it would work
          Just one method I have for further strengthening the tie bar setup to the existing points that were used to begin with. Idk yet.
            Ooppps.. I did it again! Fuuucckk iiiiiiittt! I demanded more room.. What can I say? lol
              Que??? I like 3rd gens......... just not the FS motor
              jinx. everytime i look at the front mount design now im slightly weary it'll support the torsional forces pulling downwards without cracking the welds off. I know this isn't final design.... but do you have any plans to box the back end of it shut?
              i guess i would like to see something connecting the front of the square tube to the very top most edge of the mount just for additional rigidity.
                You will just have to wait and see like everyone else I'm not even 100% convinced this is where I'm going with it. I will say that the middle section of the mounting surface is fairly thick c-channel, it's already super rigid as it is. Again this is nowhere near completed LOL Every bit of metal I've been using is well within the oem thicknesses if not thicker for applications as such. I should exceed well beyond the strength of the factory crossmember. I also have no deadline for this build, no rush or pressure.. so I can take as long as I like to play with my options
                  once it is fully welded the transmission will explode before you make half the power necessary to break that lower mounting point.
                    the mount will show signs of failing first.
                    need to finish it before I die of bordem or forget where I put parts of your harness...
                    that works really well for a couple of reasons:
                    the part of the mount that sees the highest stress is the bolting surface side of the circle.
                    the other (tiebar)side of the mount transfers the load into trying to twist that beefy piece of square stock instead of into rubber subframe mounts.
                    the rubber mount is still an oem easily replaceable piece
                    much easier to install/remove the motor
                      I like where you are going with this! I'd say go with this before dog bone, dog bone adds another degree of freedom to the engine rock vibration that isn't there normally in our cars.
                      1990 Protege 4WD 5 Speed
                        Showing how much room I still have even with the bumper brace in it's unmolested position
                          whats your plan for securing the front of the hood?
                            I'll be redoing the mid/upper portion of the valance to suit the radiator better. Similar to what I was doing with the Escort.
                              sounds good to me!
                                that black on red just pops at you, im really digging that setup man.
                                93 Mercury Tracer SW
                                01 Honda S2000 Future Boost
