Originally posted by FE3-323
View Post
2003 MSP KLDE Swap
FYI if you have a mazdaspeed you dont need the ECU for speedometer. I dont use it at all.
The speedo is done by ABS sensors. You need at least a good front and rear sensor for the speedo to work.
Originally posted by vtec-this View PostFYI if you have a mazdaspeed you dont need the ECU for speedometer. I dont use it at all.
The speedo is done by ABS sensors. You need at least a good front and rear sensor for the speedo to work.sigpic
1992 Familia GT-X
1988 323 GTX
2011 F150 Lariat Ecoboost
2014 Civic Touring
Cool. Thanks for the help. Well I just got my side motor mounts and realized I don't have any of the brackets or bolts that I thought I did... I've been searching and the only place I can find any of the brackets is at a dealer or wholesaler and they're pretty expensive. Do I have any other options when it comes to bolts, dampers, brackets etc. or am I going to have to get them from the dealer? I believe just the brackets and dampers I need would be about $220 or so. Also didn't know the diameter of bolts and nuts and what strenght I would need to get if I just went to like lowes or home depot or somethin. Ill pay the $220 but only if I know there're no other options since I just payed like $220 for the mounts themselves and I still gotta get some rims tires as well. If anyone knows what's up lmk. I appreciate the help
Millennia, no, at least the 2.3 has a different block mount for sure. 626 is the same as mx6 and Probe, and I think bolt up, but might need to be modified. You can use the stock Protege mount bracket that bolts to the frame. The KL mount slides right in.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
Okay, so I picked up some probe mounts and brackets and a 626 bracket for the passenger side but the transmission side mount does not bolt onto the frame!! I'm wondering if the protege bracket will even bolt onto the transmission. The probe I got the parts from was a 96 and neither the bracket nor the mount works so now I'm not really sure what to do. Should I buy the protege bracket that attaches to the transmission? Or will that not fit? I will post pictures soon.
I can take a picture of my transmission bracket for you tomorrow. It no longer has a KL in it, but it has the transmission I used with the KL. I can't remember what mount I used, I think it might just be the stock Protege mount though.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
