Just purchased a 2003 P5 (black) 5 speed
255k miles. clean interior & a 2nd set of rims with snow tires
all for $450.
so far it needs:
front brake rotors/probably pads
rear pads
(which means overall i will be upgrading the braking system- SS lines/ bigger slotted rotors/etc)
front balljoints & or struts
a couple potential routes i might go with this yet....
an oil change
the inside of the windows cleaned
a header
The bad:
common 3rd gen rear wheel well rust (and a few spots on the corners of the doors)
needs the front radiator support pulled back just a hair (probably able to do by hand with a few quick jerks)
headlights are also foggy
only part of the guage cluster lights work- along with the center console lights
the heater control doesn't allow full adjustment of placement (i.e. defrost/high-low/feet/etc)
meanwhile open to all suggestions
Pictures:
![Click image for larger version
all for $450.
so far it needs:
rear pads
an oil change
a header
The bad:
Pictures:
