Hello, I am looking to replace my stock shifter bushings...the ones that go into the base of the shifter (and also the end of the shifter arm...right next to the kartboy ones) with some aftermarket bushings if they exist. I already have the kartboy bushings, but that is for a different place. the mazda part number the ones I want is 46-062a and i will just get new ones from them if there is no such thing as a preformance one...but I thought I'd check before I paid $4.30 a piece for OEM ones since I need 4.
If you have the left to right play in your shifter...replacing these bushings will fix that...at least I'm hoping it will...
you most likely will need to replace all 4 though, or if not just the ones up next to the kartboy bushing location.
here is a picture for better description...where it is pointing and says "is this it"...well yes it is!
[IMG]http://jonkinney.com/bushings**********
