yeah i just bought a 2001 es 2.0 and all the maintence i have no clue as for like the timing belt, o2 sensor, clutch and other items like that. although my passenger side motor mount is already taking a crap on me so i have to change that soon before i get more problems from the other ones. so yeah any help i would greatly apprecitate it thanks
When is a good time to change the timing belt/chain???
If you've got the owner's manual, it will have a complete chart of recommended maintenance intervals.Ryan The middle child is always ignored
Usually every 60,000 miles.
If you don't know wether or not its been changed and you've got 60,000 + then I would change it as a precautionary measure.
The clutch and O2 sensor you change when they "go".
The clutch will eventually wear out.O2 sensors shouldn't wear out or whatever, but they seem to have a life expectancy of ~ 100,000 miles or so.
On my second gen it went around 160,000 KM give or take. and other second genners seem to have had to replace it around the same time, but its one of those things where it works or doesn't. THey won't gradually fail the way a cluch or brake pads will wear over time.Ryan The middle child is always ignored
According to the '02 FSM, under normal driving conditions in the USA:
Inspect at 60,000 miles (96,000 km).
Replace every 105,000 miles (168,000 km).
The same intervals apply to cars operated in Canada, Puerto Rico or in the USA under Unique driving conditions (as defined in the FSM).
Finally, for vehicles operated in cold districts below 0 deg F (-18 deg C):
Replace the timing belt every 60,000 miles (96,000 km).
