to get the MAF screen out you just have to tap one side of it, then the other, and keep alternating till it wiggles free. mine felt a little stuck too but when i tried wiggling it it came out no problem.
Modifying the Stock Air Intake System
Well, I did the tapping thing.....for several minutes too. I used the end of a wrench that was long and thin enough to fit through without touching anything else. I then went back and forth, side to side, tapping fairly gently at first then a bit harder and nothing. Not even a budge. Maybe it sort of seized up in there over the years (2002 P5 model).
Its irritating since just by looking at it you kind of can tell it slows airflow down, albeit not dramatically IMO.
I may try to tap it out with a small light hammer that might dislodge it better. I still want to do this last mod.
I am not very hands on with my car but I am learning what I can about these great little cars. For the life of me I have NO clue where you guys are cuttingNot your fault mind you well maybe some of it is. Some pics are not showing up. I need better visuals I guess, can anyone show me please where & what excatly you cut? I have a 2000 Protege ES with a 5 Speed that I'd love to free up some extra power not matter how little starting out.
Thanks in advance.Last edited by norwood1026; 08-24-2009, 08:26 PM.Got Zoom?
2000 Protege ES
Well, its not so easy to describe with words. Out of the some 200 posts in this thread over the years, there are both very detailed written descriptions of where to cut (first page) as well as numerous pics posted, mixed in random posts. On the other hand, take your car, open the hood, note where the airbox intake opening is (over the rad, left side), close hood slowly and you can figure out that the intake gets basically blocked by the hood. Now figure out where you would cut to open it, obviously not through the hood. The only direction to free up some intake open air is straight down, through some hard black plastic, sort of immediately on the other side of the steel car frame. Hope this helps.
Originally posted by LarryP View PostWell, its not so easy to describe with words. Out of the some 200 posts in this thread over the years, there are both very detailed written descriptions of where to cut (first page) as well as numerous pics posted, mixed in random posts. On the other hand, take your car, open the hood, note where the airbox intake opening is (over the rad, left side), close hood slowly and you can figure out that the intake gets basically blocked by the hood. Now figure out where you would cut to open it, obviously not through the hood. The only direction to free up some intake open air is straight down, through some hard black plastic, sort of immediately on the other side of the steel car frame. Hope this helps.
Thanks I was worried about getting an anwser because the topic goes back some years. I saw one picture where it was showen from the top looking down. I think I understand where I need to cut now I guess I need to remove the grill to do this correct?Got Zoom?
2000 Protege ES
Originally posted by SAprotege02 View Postno, it's even easier than that. you just have to open the hood and the place where you cut is located directly under the air inlet. the black tray looking piece of plastic.
Daddy is VERY happy with this mod. I was a bit worried at first & I didn't have all the right tools but I got done it was worth it. Car does rev higher & quicker I notice it more in second gear then any where else third also. I did disconntion the neg battery for like 30 secs. No flashing lights no nothing. I did not remove the MAF screen because I have NO clue where it is & how to get it out. Might just have to wait to the next local club meet! Thanks everyone!
I LOVE IT!Got Zoom?
2000 Protege ES
Overview: How Air Intake Mods Affect HP Output
For those of you who are interested, I just updated this thread. Because of its length, I thought it a good idea to add an overview which summarizes the effects of the mods described here for those who might wish to carry them out on their own.
Most of you are aware that the crank or BHP of an engine is positively correlated with intake air density and negatively correlated with intake air temperature. Recalling that air density is defined as the weight of air for a given volume, and that the MAF sensor meters on air density, locating the air inlet in a high pressure area, reducing negative pressure in the intake duct and ensuring that the intake air temperature is at the ambient rather than above, have the effect of increasing intake air density. It's for these reasons that the intake mods previously described here have resulted in at least a moderate increase in power output and performance. However, there is an additional reason for the performance increase that may not be as evident.
We know that BHP = IHP - FHP, where FHP is the HP consumed by internal engine friction. But FHP has two components: mechanical friction between moving parts, especially piston motion in the cylinders, and fluid friction in the intake and exhaust systems including the flow through the valves and motion within the cylinders. It's this second type of friction, also known collectively as pumping losses, that concerns us here.
Anything that enables the downward movement of the piston on the intake stroke to more easily 'pull' the intake charge into the combustion chamber, such as a high pressure air inlet and reduced intake duct restrictions, results in a reduction in pumping losses and consequently a decrease in FHP.
In like manner, a freer-flowing exhaust system will reduce pumping losses (reducing the work required of the piston to expel the burnt gases on the exhaust stroke) and generate a similar effect. However, that's a topic for another thread.
To recapitulate, there are two reasons for any noted performance increase due to the modified OEM system described here: an increase in intake air density and a reduction in pumping losses.
Reference: Engineering Fundamentals of the Internal Combustion Engine, Second Edition, by Willard W. Pulkrabek; Chapter 11: Friction and Lubrication, pages 410-442.
Wow good thing I kept all my stock pieces! I replaced the stock system with an aftermarket filter and tubing after discovering my flex tube had cracked (not so flexible after 100+k miles i guess) I think I'll round up my snorkel, bust out the dremmel n give this shot. :D
Only question I have is, since my flex tube is f***d would u suggest buying a oem replacement or would a smooth silicone tube be less restricting? I know the point of the flex is so it moves with the motor since it's mounted to the body, but I made a custom bracket(...actually my hubby did that part<3) to mount on the transmission harness bracket for my current aftermarket setup. Don't know how much difference a smooth surface would make vs ribbed, just always heard flex tube restricted air flow.
Gotta give kudos to Goldstar for this inspiring thread! Wish I had tomorrow off so I could get started, I'll let yall know how it goes
Thanx Againsigpic
Mod List:
*KYB GR2 Struts
*Modified stock intake
*K&N Performance air filter
*Stainless Header
*Custom Interior- hot pink / black carbon fiber wrap
*Urethane Filled Mounts (1 done so far)
*Alpine 600W Amp / Audiobahn 12" Sub
In theory, a smooth internal bore might be slightly less restrictive than the OEM flex tube air hose but since I've never tried that mod I couldn't say for sure. As you point out, the flex tube is necessary to accomodate the relative movement between the engine and the chassis-mounted parts of the induction system but if you have a custom mount that accomplishes the same function, a smooth bore silicon tube should be just fine. It certainly couldn't hurt.
If you have any other questions, don't hesitate to ask.
zoomzoom chick, thank you very much for your kind words about this thread, and I'm glad that you found it useful. Please do let us know about how the mod works for you as I know many of us will be interested in your evaluation.
Originally posted by rwindleyme02 View PostHey guys, I know this is my first real post and I don't want to step on any toes by giving my professional opinion on this post. I'm a mechanical engineer and have done numerous mods to my car and wanted to share my experience with you guys with reguard to these mods.
First off, the "air ram" mod is a pretty good mod IMO. I'd go the conservative route and only block up half. If you wanted to run a total blocking of the grill, invest in some water wetter to lower your radiator temps if it gets hot in your area.
Next thing is the MAF screen and the fact that people are removing it without knowing what it does or exactly what effect it has on HP. You guys are exactly right, it serves no protective purpose. If a chunk of something that big gets into your engine, you've got bigger problems with your air filter! The MAF screen infact reduces turbulence into the sensor. The sensor takes airflow data, whatever it may be, and adjust A/F ratios accordingly. The "waffle" design is just a cheap way to smooth out the air. What you guys are feeling in terms of revving more freely or butt dyno gains are just that, placebo effect. Dynos have been done on various cars with the stock MAF, w/o the MAF grid, and with specially designed grids engineered to maximize flow while still create more laminar airflow. In all cases that I've seen, (except for one case of a re-designed grid), the stock grid produces more HP than messing with the grid by cutting it or removing it alltogether. Even the example I have seen that did produce a dyno with positive results has also seen negative results in some cars.
Again, I don't want to be the bearer of bad news, but as an enthusiast & engineer, I want people to get the most out of their cars. In summary, do the "air ram / snorkel" mod (and change your airfilter often) but don't remove the MAF grid.Originally posted by nicodeemus View PostI've now modified both of my Protege's (2001 ES 2.0 manual tranny and 2002 LX 2.0 auto tranny). I've seen improvements in both. The auto's revs drop way faster now and both are a lot smoother and peppier off the line. I've built some custom bug guards for both of them to keep large bugs out of the air filter box. I made them out of speaker grill covers. They have about 1/8" holes in them and don't seem to restrict the air flow. I've tried them both on and off and I can't notice any huge difference in performance, so I'm keeping them on to help with the buggies. Here's some pics....
Originally posted by zoomzoom chick View PostWow good thing I kept all my stock pieces! I replaced the stock system with an aftermarket filter and tubing after discovering my flex tube had cracked (not so flexible after 100+k miles i guess) I think I'll round up my snorkel, bust out the dremmel n give this shot. :D
Thanx Again
While I agree with rwindleyme02's description of the purpose for the MAF screen (I was thinking of posting a more primitive explanation myself), what he didn't tell you is that the screen in fact reduces the "free area" maybe as much as 50%. This is typical of all perforated screens. So, while it evens out the flow of air it also reduces it. Removing it is a compromise, less accurate readings for the sensor but increased air volume to the engine.
So, nicodeemus, your bug screen is also a restriction of air (sorry guy, good idea for keeping out bugs, but kind of a 2 steps forward, 1 step back thing).
zoomzoom chick, the flex tube also causes some air restriction due to turbulence. A smooth wall would be better.
Here are a few basics in regard to air flow from the dumb guy;
1) Flex or corrugated surfaces are bad, smooth surfaces are good.
2) Sharp corners and angles are bad, long radius turns are better.
3) Many bends and turns are bad, straighter paths are good.
That's all I got.
P.S. I plan on doing some of these mods too.
rwindleyme 02: Thanx for the info one the screen, I was probly gonna leave that mod out simply because the benefit to my daily driving (though I try to make it as exciting as possible) didn't outweigh the cost of replacing the MAF if somethin did go wrong
nicodeemus: I thought about doin the same thing with some random mesh I found in the garage yesterday. I also encounter lot of "buggies" where im at so it made sense at first but it did seem like it would defeat the purpose alittle, after all our grill should do most of the bug catching
Kev aka "dumb guy" lol thanx for the tip, I've decided on silicone tubing.
After taking another look at my setup, can anyone tell me if that resevoir-like piece that would sit next to the radiator serves a purpose? I havent had time to install anything yet but i didnt see the point except i guess for water drainage?
Im off tomorrow so I plan on getting started first thing!sigpic
Mod List:
*KYB GR2 Struts
*Stainless Header
I thought this topic had been adequately covered and laid to rest but since it has surfaced again I'll return to it.
rwindleyme02's claim that removal of the MAF screen produces no positive results (reduction in negative air pressure) appeared in post #130, page 9 of this thread. I responded to it in my post #131 in which I pointed out the existence of data indicating that removal of the screen did in fact reduce negative pressure in the intake air duct after the MAF sensor (in one instance by 19%), and has the potential to increase power output at maximum rpm. The data comes from two references that I relisted in my post #131 and earlier listed in post #2 where I first discussed removal of the MAF sensor screen. I also pointed out that I would not recommend removal of the MAF sensor screen without the existence of data showing a positive effect. I don't recommend mods just because I "think" they're beneficial.
I agreed with rwindleyme02 that the function of the screen is to reduce turbulent flow through the MAF sensor, not to serve a protective function, which I had already pointed out in post #2. Since the intake air must turn after flowing through the air filter element to reach the MAF sensor, the potential for an increase in turbulent flow, and consequently less accurate metering, exists. However, I, along with Edgar and Bell, believe that the increase in turbulent flow is trumped by the reduction in negative air pressure in the intake duct. However much the increase in turbulent flow over the more desirable laminar flow, and whatever its effects on MAF sensor metering, as I've stated before I've never noticed any negative effects due to this factor. Since I felt screen removal gave a noticeable increase in performance in my car, I recommended that others should try it. Whether or not you do so is strictly a personal choice.
And yes, any screen, or mesh, placed anywhere in the induction system will result in an increased pressure drop, just the opposite of what we're trying to achieve here.
Happy Motoring!Last edited by goldstar; 03-28-2010, 03:06 PM.02 DX Millenium Red - The Penultimate Driving Machine
Originally posted by zoomzoom chick View PostAfter taking another look at my setup, can anyone tell me if that resevoir-like piece that would sit next to the radiator serves a purpose? I havent had time to install anything yet but i didnt see the point except i guess for water drainage?
However, Helmholtz resonators that affect low speed torque (cylinder filling at low rpms) are usually located between the air box and the TB. Those devices located before the air box, as in our case, usually are there to perform a silencing function for the intake air and have nothing to do with restoring low speed torque. This is the position taken by Julian Edgar and I refer you to his commentary on the subject in AutoSpeed, titled "Those funny things tee'd into intakes...". You can access it at:
I used to think that our Helmholtz resonators were employed to increase low speed torque but after reading Edgar's blog, now I'm not so sure.
I've never removed mine so I don't know what effect its absence would produce. Note however, that it is not inline with the induction system but rather in parallel to it so it shouldn't act as a restriction to air flow. Therefore, to be on the safe side, I would advise leaving it in place and not worry about it unless you care to experiment to determine its effect. If so, be sure to let us know your conclusions.
Good luck with your project.
Happy Motoring!Last edited by goldstar; 03-28-2010, 03:01 PM.02 DX Millenium Red - The Penultimate Driving Machine
I completed mod #1 on Sunday, cutting the opening in the horizontal grill support, and so far thats gone well. I haven't had time to play with anything else, been busy helping my husband put a couple of his cars together n get them moved cuz the "city ordinance" is givin us crap for having too many cars (They're just jealous!) Hopefully the craziness will be over soon n I can get back to play time! Here's a pic of my progress so far...
I had trouble gettin the image to show up so it can also be viewed at
http://www.myspace.com/jennscott626 under my pics - car mods
Goldstar, both views seem to make sense...maby both are right...either way my curiosity tends to overrule my sense so Im gonna try it without first, worst case I have to stick it back on. I will let yall know what happens
I've also decided to paint my airbox n a few other various under-the-hood components pink.Although this will result in absolutely zero gain in my cars performance (duh!) it will look friggin awsome!!! This might delay my project alittle but I'll keep postin my progress
Mod List:
*KYB GR2 Struts
*Stainless Header
