Does anyone know of a limited slip diff that will work for a '99 Protege? Quaife makes one, but it runs $1300.00. Does anybody know of one that's cheaper?
LSD help
the mazdaspeed one if you have a g box.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
quaife is top of the line tho---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
