I have a 02 protege ES with an auto trans... i was wonder i had found a 02 protege 5 with a manual trans... i want to put the motor and trans in my car but i was wondering if i need a different wire harness or if the one for my auto was the same..
Manual conversion
k i swapped my nex motor and trans up... went in super smooth... but idels really rough...... im just wondering if anyone can take a picture of where they landed there last wire... just before the ground post of there battery.... and if you have any idea how to smooth out my motor... please let me know.... dun_18@hotmail.com
This is nothing but a pure guess, but it could be that that the ecu has a slightly different program and that you need to have yours flashed. I would check to make sure you're getting a good spark to each plug and you may also want to check the timing. Clean your sensors, idle control valve and throttle body. Make sure the EGR is working right and check for any engine codes.
Originally posted by dtatham View PostThis is nothing but a pure guess, but it could be that that the ecu has a slightly different program and that you need to have yours flashed. I would check to make sure you're getting a good spark to each plug and you may also want to check the timing. Clean your sensors, idle control valve and throttle body. Make sure the EGR is working right and check for any engine codes.
