hello guys my girlfriend has a problem with her car. theres a really bad squeal from the belts or something under the hood when the car is turned on and its even worse when the heat or ac is on. the belts have been tightened and we have thought about spraying the **** outta them with belt dressinig does anyone have an idea of what the culprit may be? thanks!!
bad squeal coming from engine..Belts..tensioners??
Originally posted by Chad View Postwell maybe the belt is too tight? try spraying it see how that works.. how old is the belt, what condition does it look to be in03 CC LB Nissan Frontier, bunch of mods
99 Mazda Protege (Girlfriends) bone stock
The belts that are supposed to go on it run a bit long and after a few months they will stretch to the point that adjusting them no longer tightens the belt. Pick up a tension tester to see if they are tight enough. I found that the NAPA brand were the only ones I didn't have to replace after about 4-6 months.
Originally posted by dtatham View PostThe belts that are supposed to go on it run a bit long and after a few months they will stretch to the point that adjusting them no longer tightens the belt. Pick up a tension tester to see if they are tight enough. I found that the NAPA brand were the only ones I didn't have to replace after about 4-6 months.03 CC LB Nissan Frontier, bunch of mods
Originally posted by TheOregonFront View PostWOOOOOOOOOHHHHHHOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!
thanks i will replace it and see if its stops!!!!I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important.
._________________________
Originally posted by wheresthericego View Posthope youre ready to take out the timing belt to change the waterpump03 CC LB Nissan Frontier, bunch of mods
Check the seep holes on the water pump. You generally start loosing coolant, with a need to add once a week or so, before you get any squealing. If you aren't loosing coolant, you need to do some more checking. It could be a tensioner pully on your timing belt. If that's the case, don't drive it until it's fixed.
squealing belts
I generally get at least a couple years out of the belts that I get from Napa. Then again, I live in Florida and it doesn't get very cold. I never got more than 8 months for belts I bought anywhere else. They stretch to the point where there isn't any more room to tighten them in a few months, in fact they are almost tightened to the limit of the bolts when first installed.
this happened to my Protege a couple of years ago. I tried everything and finally found an old pro in Oklahoma City. He had me turn the car on, turn all the accessories on to max out the alternator. From a spray bottle, he sprayed the alt belt, and poof, noise gone. I had tightened that belt about two weeks before, but obviously not enough. Check your alternator belt again.
