doing clutch on 99 Protege,I need torque specs ETC
    I need torque specs for the flywheel and clutch, gear oil type, axle nut size ETC;
    I looked online and the specs i got where:
    flywheel- 71-76
    clutch 13-20
    thanks
    DailyDriver/Grocery getter:
    1986 Toyota Corolla GT-S 4AGE 16v Hi-comp/TRD/LSD
    RUN 4AG!
    Originally posted by Haynes Repair Manual
    Flywheel bolts: 71-76 ft-lbs
    Clutch pressure plate-to-flywheel bolts: 14-19 ft-lbs
    Driveaxle/hub locknut: 174-235 ft-lbs
    Gear oil: API GL-5, SAE 75W-80 gear oil
    Never run out of real estate, traction and ideas at the same time.
      thanks grind. your a freakin lifesaver!!
      RUN 4AG!
        Finally finished the clutch swap during the weekend. took awhile cuz ive never messed with FWD tranny & axles.
        once again thanks Grind
        RUN 4AG!
