Originally posted by dahotprotege
2.0 Jspec
Ive heard that too. Allegedly you want nothing more than 9.1 compression before turboing otherwise you will have to use such a low compression on the turbo it makes it almost redundant. The only thing to get around that i guess would be to beef up the internals so they can take the higher compression stroke and also the turbo compression. Its all addative remember and you dont want to have a piston fly through your bonnet because you were running 15pounds and 9.8 =p
a good compression would be around 9.4. you can buy the intake manifold, pistons, cams and header from the FS-ZE from corksport (well, i think they're out of exhaust cams, you can get them from www.shaneracing.com)...anywho, it'll bump up your HP a ton. probably not 170, but it'll bump it up.
my goal is to have 200+ hp to the wheels n/a...i have the cams, a header, and other crap...once i get the pistons (hopefully late spring...i plan on getting forged rods too) and get it tuned, i'll be there.
but back to the topic...high compression + turbo is NOT a good thing at all. you can get FS-ZE parts without buying the whole motor. so check into that.
hope that helped.12003 Spicy MSP
2003 Mazda Protege5 - traded
2001 Mazda MP3 #1476 - sold
OK, time for MY stupid question for the day... if you buy any of the parts from the FS-ZE and install them, will they all bump the compression? I mean, couldn't you buy the camshafts and get the 18 or whatever extra hp and then turbo it without hurting anything? Or the larger throttle body? As long as you don't get into high compression stuff, shouldn't it work fine?
yes, just don't do the pistons...that's the only thing that bumps up the compression. i have a friend who had a mazdaspeed with j-spec cams...that was a damn fast car. the larger throttle body is a waste of money...it only shows VERY small gains if your car is turbo'd.2003 Spicy MSP
2.0...go for the hiboost kit...it kicks ass. www.hiboost.com2003 Spicy MSP
Originally posted by Topherbut back to the topic...high compression + turbo is NOT a good thing at all. you can get FS-ZE parts without buying the whole motor. so check into that.
hope that helped.1Ryan The middle child is always ignored
riiiiiiiiiiiiight...but there's no one around here that can tune my car for that kind of set-up. **** like that isn't readily available to everyone.
jnorion, get those parts...get the hiboost...and you'll have a bad ass car. juan at hiboost ran a stock p5 with his kit up to 14psi without any problems and put out 260 or 240 (i don't remember) hp to the wheels. of course, you wouldn't want to run that daily...just let him know what you're doing and he'll tell you what you'll need.
-Chris2003 Spicy MSP
