It sounds like to metal objects hitting each other. Or a loose nut. I can't find it anywhere on the web on what could be the problem. I just had the clutch replaced and one of the mechanics said it could be my pressure plate. I was looking under the hood to figure out what was wrong with it when a Protege5 came rolling through with the same clinging sound. Is this normal for all proteges? I need help.
Clinging sound coming from the right pasenger side
when does the sound occur most often? are you driving? is the car idling? are you cornering? can you duplicate it under specific conditions? i dont suppose you could get a friend to record the sound on their camera or phone? i've been trying to diagnose random squeeks, rattles, and clunks for years but have not gotten far.
one common sound i hear is that of a random nut/bolt flinging around. could just be winter squeeks, or a pebble fell in somewhere. it goes away after a while when i assume the pebble makes its way out.
another sound i've figured out was the hood latch. occasionally makes a metal clinking noise when i go over bridge joints or something like that.
and finally the heat shield under the exhaust pipe tends to rust and rattle away.
Originally posted by meGrimlock View Postwhen does the sound occur most often? are you driving? is the car idling? are you cornering? can you duplicate it under specific conditions? i dont suppose you could get a friend to record the sound on their camera or phone? i've been trying to diagnose random squeeks, rattles, and clunks for years but have not gotten far.
