My name is Jon I own a 2003 MazdaSPEED PRotege manual and the engine just blew a hole in the block and I am wondering if there is any replacement motors I can put in it other than the original because apparently there is none, and put the turbo on another 2.0L Manual.
2003 MAZDASPEED PROTEGE 2.0L Manul Turbo engine replacement
Welcome to the Forum.
You can replace your engine with any 2.0 L FS-DE normally aspirated engine from model years 2001-2003 (including the MP3 and the P5) and then convert it over to turbo using the parts you already have.
