So a week ago I bought a 99 protégé with a 5 spd and 1st gear doesn't work 99% of the time. It usually just grinds when I let go of the clutch when I try to engage 1st. I've gotten it to work 3-4 times, but I don't know how. All the other gears work perfectly fine. So whats going on with my trans?
1st gear wont engage.
First thing I would check is your brake fluid reservoir. It is also the fluid for your clutch master cylinder, which creates the hydraulic pressure to disengage the clutch when you push in on the clutch pedal. If its low that could be a problem. It could also need to be adjusted, or bled. You could search the forum for all the possibilities for the shifting problem. Most indicate probable issue with clutch, either the master cylinder, or the throw out bearing worn down.(inside transmission)That should be replaced when clutch is replaced. Do you know much about any maintenance on the car?
If the shifter is really sloppy on the car. Fix that first. Sometimes if it's too sloppy it will not let it go into gear. Does it go into all the other gears no problem? What about reverse?91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by dadio4 View PostFirst thing I would check is your brake fluid reservoir. It is also the fluid for your clutch master cylinder, which creates the hydraulic pressure to disengage the clutch when you push in on the clutch pedal. If its low that could be a problem. It could also need to be adjusted, or bled. You could search the forum for all the possibilities for the shifting problem. Most indicate probable issue with clutch, either the master cylinder, or the throw out bearing worn down.(inside transmission)That should be replaced when clutch is replaced. Do you know much about any maintenance on the car?
Originally posted by progt91 View PostIf the shifter is really sloppy on the car. Fix that first. Sometimes if it's too sloppy it will not let it go into gear. Does it go into all the other gears no problem? What about reverse?
Check your transmission fluid level. low fluid makes for difficult shifting---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
you need to pull out the speedo gear & check the fluid level there---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
rear side of the transmission ~right below the throttle body---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
