This is a lady i work with posting this at work. I have never had an engine issue with my P5 so have no experience. woudl like to know if there are any ideas i can relay. Car has 145k miles on it.
"About 4 months ago my car (2003 Mazda Protege5) stalled out -- I had to get it towed, and paid my mechanics a small fortune for repairs. (Apparently one of the cylinder heads on the engine needed to be re-machined. In hindsight I probably should have retired the car.) Anyway, listed on my invoice for that repair is "machining/resurfacing including complete valve job and valve adjustment", as well as a new engine gasket set.
Ever since I got my car back, it's been consuming oil at a rather astounding rate (about 1 quart every 2-3 weeks). It's never done this before, so I'm assuming that it has something to do with the engine being stripped down 4 months ago. Seeing as these mechanics warranty their work, I took it back to them. They replaced the PCV valve (didn't charge me for labor), said to monitor oil consumption, and advised me that the engine valve rings are worn. By this, I assume that they mean the valve seals.
My question is: are they pulling a fast one on me? Would one also not replace the seals with the valves? Or at the very least, wouldn't you notice that they're heavily worn when doing the whole engine rebuild?
