Ebay Intake Help(Not what you think)
    he needs help on installing it I think. Its pretty simple I did mine myself and it only took me like 45 minutes the hardest part was taking out the stock intake.
    2000 DX 1.6L
    17" Enkei RS7 Gunmetal
    Kumho ECSTA'S 205-40-17
    TEIN S-Tech Springs
    Ebay CAI customed to short intake with RACTIVE heatshielded cone filter (blue)
    M3 blinker mirrors
    NGK Iridium IX
    Next Gen Rear lights
    Diamond Clear Corners
      i just ordered an intake off of ebay and il have no problem installing it, but i have a question about the neg. terminal, do you have to unhook it and if u do how long should it be done for and what are the advantages?
      thanks
      brian
        You would unhook the neg terminal to reset the ECU I did mine for an hour. Another thing that you want to do is seal the MAF really good its known to have vaccum leaks like the others posted b4. I did that with some gasket making goop that you can buy at auto stores, or you can make a gasket yourself from an used inner tube.
        2000 DX 1.6L
        TEIN S-Tech Springs
        M3 blinker mirrors
        NGK Iridium IX
          Hmmm, I thought the ECu reset was: remove neg. terminal and hold the brake pedal down for @15 seconds...
          '03 Sunlight Silver ES/5sp
          THUNDER 4-1 RACING HEADER
          Racing Beat Exhaust, SPD Racing SRI
          Eibach Pro-kit, MP3 ECU, MP3 Foot Pedals
          Powdercoated stockers wrapped in Yoko AVS ES100s
          Kartboy SS/Knob/Bushings
            I never heard of that maybe someone could clear that up.
            2000 DX 1.6L
            TEIN S-Tech Springs
            M3 blinker mirrors
            NGK Iridium IX
              that is correct!
              .....HELLO MY NAME IS BEN...
              186.08whp
              225.94wtq
              torque monster!!!!
              dyno graph 8-10-and 12psi
              blahblahblahblahblahblah
                i installed my intake finally and it is awesome, i didnt do the brake pedal thing should I? i reset the ecu just with the neg cable disconnection. It is blue same color as my car pix are on my cardomainpage
                2003 Mazda Protege LX
                Laser Blue
                www.cardomain.com/id/thejackyl
                Old Car
                1998 Kia Sephia LS
                Custom Front Bumper, motegi gunmetal mr7s wrapped in Nitto 450 Xtremes, OBX exhaust, Custom CAI, CUstom interior
                  Depressing the brake pedal is just a fail safe way to make sure the electrical system is completely discharged. If you had the negative terminal disconnected for 10 minutes or so, I wouldn't worry about it.
                  Clint/1999 "Sport20"
                    ya it was disconnected the whole time i was installing the intake so that ok?
                    Laser Blue
                    Old Car
                    1998 Kia Sephia LS
                      It should be fine. Did you notice your tranny wanting to shift sooner than normal first time you started the car up? The tranny has to 're-learn' your shift points over time.
                        actually good point i forgot bout that, but it seems to shift later now....
                        Laser Blue
                        Old Car
                        1998 Kia Sephia LS
