Meh... 40 bucks plus 20 or so for shipping. Actually, i found out that there is no place in town that can do mandrel bends, so once i save up some cash, ill probably get an ebay CAI. Does anyone know, where the pipe routes through? There is that hole under the coolant resivoir that is the best place for it, and the resivoir can be moved.
My new intake!
Originally posted by goldstarActually, the OEM air filter is not at all restictve. Based on the accepted 1.5" water pressure drop through a clean filter, the stock filter is more than adequate up to 7000 RPM for the 2.0L engine. For more information:
Ambient intake air temperature has a significant effect on HP output. Based on SAE J1349 standard for HP measurement, an underhood intake air temperature, of 120 deg F (48.89 deg C), for example, will reduce HP output of the 2.0L engine from 130 to 124, a reduction of 4.4%. For a fuller explanation, look at: www.wihandyman.com/forum/showthread.php?t=995My MAM SS Kit Install Thread | Gauge Customization kit - LEDs, icons, more! Sample:
Originally posted by glyphgoldstar to the tech rescue again, (except you said "fuller"; hee hee). Just can't take you seriously now... tsk tsk
02 DX Millenium Red02 DX Millenium Red - The Penultimate Driving Machine
